Unstable WDS link
I have two RB511 configured with WDS. The link is very intermittent and I get high packet loss although the devices have good signals levels (better than -68dbm 99% of the time) according to the registation tables. The problem seems to be worse at certain times.
Below find some detail:
Ping between the two units:
10.100.100.16 64 byte ping: ttl=64 time=309 ms
10.100.100.16 64 byte ping: ttl=64 time=374 ms
10.100.100.16 64 byte ping: ttl=64 time=682 ms
10.100.100.16 64 byte ping: ttl=64 time=18 ms
10.100.100.16 64 byte ping: ttl=64 time=288 ms
10.100.100.16 64 byte ping: ttl=64 time=212 ms
10.100.100.16 64 byte ping: ttl=64 time=356 ms
10.100.100.16 ping timeout
10.100.100.16 64 byte ping: ttl=64 time=369 ms
10.100.100.16 64 byte ping: ttl=64 time=107 ms
10.100.100.16 64 byte ping: ttl=64 time=767 ms
0 interface=wlan1 radio-name=“500_Block_To_Com” mac-address=00:0C:42:05:18:71 ap=yes wds=yes
rx-rate=48Mbps tx-rate=54Mbps packets=9907,2747 bytes=792819,400838 frames=9907,2908
frame-bytes=734385,386016 hw-frames=13377,2918 hw-frame-bytes=1315348,456068 uptime=1h51m14s
last-activity=410ms signal-strength=-66dBm@9Mbps signal-to-noise=22dB
strength-at-rates=-66dBm@1Mbps 2m28s930ms,-66dBm@9Mbps 1h45m24s60ms,-66dBm@12Mbps 1h43m12s540ms,-
66dBm@18Mbps 1h43m6s510ms,-66dBm@24Mbps 1h42m58s420ms,-66dBm@36Mbps 10m44s570ms,-
69dBm@48Mbps 8s750ms,-70dBm@54Mbps 8s810ms
tx-signal-strength=-60dBm tx-ccq=96% rx-ccq=85% p-throughput=5857 ack-timeout=56 distance=56
nstreme=no framing-mode=none routeros-version=“2.9.18” last-ip=10.100.100.16
802.1x-port-enabled=yes authentication-type=none encryption=none compression=no
[admin@500_Block_To_ComputerRoom] interface wireless> registration-table print interval=1 stats
0 interface=wlan1 radio-name=“Computer_Room_Ex” mac-address=00:0C:42:05:09:78 ap=yes wds=yes rx-rate=54Mbps tx-rate=48Mbps
packets=2865,9523 bytes=395908,773507 frames=2865,9621 frame-bytes=380068,717834 hw-frames=2865,9631
hw-frame-bytes=448828,948998 uptime=1h47m33s last-activity=0s signal-strength=-60dBm@54Mbps signal-to-noise=36dB
strength-at-rates=-54dBm@1Mbps 2m40s330ms,-57dBm@6Mbps 1h47m22s500ms,-58dBm@9Mbps 11m38s40ms,-57dBm@12Mbps 1h47m12s880ms,-
57dBm@18Mbps 1h47m11s150ms,-56dBm@24Mbps 7m57s680ms,-56dBm@36Mbps 3m12s610ms,-59dBm@48Mbps 10s610ms,-
60dBm@54Mbps 10ms
tx-signal-strength=-67dBm tx-ccq=79% rx-ccq=93% p-throughput=36544 ack-timeout=56 distance=56 nstreme=no framing-mode=none
routeros-version=“2.9.18” last-ip=10.100.100.11 802.1x-port-enabled=yes authentication-type=none encryption=none
compression=no
Wireless scan shows low utilisation of the frequency spectrum.
Monitor on 10.100.100.11
notify-external-fdb: no
status: running-ap
band: 2.4ghz-g
frequency: 2437MHz
noise-floor: -88dBm
overall-tx-ccq: 99%
registered-clients: 1
authenticated-clients: 1
current-ack-timeout: 56
current-distance: 56
nstreme: no
current-tx-powers: 1Mbps:19,2Mbps:19,5.5Mbps:19,11Mbps:19,6Mbps:19,9Mbps:19,12Mbps:19,18Mbps:19,
24Mbps:19,36Mbps:18,48Mbps:17,54Mbps:16
Monitor on 10.100.100.16
status: running-ap
band: 2.4ghz-g
frequency: 2437MHz
noise-floor: -98dBm
overall-tx-ccq: 97%
nstreme: no
current-tx-powers: 1Mbps:20,2Mbps:20,5.5Mbps:20,11Mbps:20,6Mbps:20,9Mbps:20,12Mbps:20,18Mbps:20,24Mbps:20,36Mbps:18,
48Mbps:17,54Mbps:16
Any ideas what else I can do to do more detailed troubleshooting and get to the root of the problem?
Noise floor of -88 on one of thw units, that not good
Also, try 802.11 B see if that helps?
Have you treid a channel change?
:slight_smile:
Changed the channel to 1 which resolved the problem. There is obviously some from of interference that seriously affects the other channels.
