Hello.
I got issu on my ap, clients stands 48Mbps/48Mbps
but go back to 48Mbps/6Mbps often and then up to 48Mbps/48Mbps agein.
When i look at the clients it standing 48Mbps/48Mbps not dropping.
And the ccq is not good its 80/85 % but dropp down to 70/70 % and can ho up to 80/97%
but look like the tx ccq that is the most unsable
Rely unstable, what can do this? signal is -72/-73 and stable. nosie to flore 23 troput 26214 kbps
AP:
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no
antenna-gain=0 antenna-mode=ant-a area=“” arp=enabled band=5ghz
basic-rates-a/g=6Mbps burst-time=disabled comment=“” compression=no
country=no_country_set default-ap-tx-limit=0 default-authentication=no
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none
disable-running-check=no disabled=no disconnect-timeout=3s
frame-lifetime=0 frequency=5260 frequency-mode=manual-txpower hide-ssid=
no hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=4 l2mtu=2290 mac-address=
00:0C:42:60:EF:55 max-station-count=2007 mode=ap-bridge mtu=1500 name=
wlan1 noise-floor-threshold=default on-fail-retry-time=100ms
periodic-calibration=default periodic-calibration-interval=60
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=
000C4260EF55 rate-set=default scan-list=default security-profile=default
ssid=ggnetAP203 station-bridge-clone-mac=00:00:00:00:00:00
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
tx-power-mode=default update-stats-interval=disabled wds-cost-range=
50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no
wds-mode=disabled wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 comment=“” manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,
6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps
:17,HT20-0:0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:
0,HT40-0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-
Clients:
/interface wireless
basic-rates-a/g=6Mbps basic-rates-b=1Mbps burst-time=disabled comment=“”
compression=no country=no_country_set default-ap-tx-limit=0
default-authentication=no default-client-tx-limit=0 default-forwarding=
yes dfs-mode=none disable-running-check=no disabled=no
disconnect-timeout=3s frame-lifetime=0 frequency=5300 frequency-mode=
manual-txpower hide-ssid=no hw-fragmentation-threshold=disabled
hw-protection-mode=none hw-protection-threshold=0 hw-retries=4 l2mtu=2290
mac-address=00:0C:42:3A:86:A1 max-station-count=2007 mode=station mtu=
1500 name=wlan1 noise-floor-threshold=default on-fail-retry-time=100ms
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=GG_C0006
rate-set=default scan-list=default security-profile=default ssid=
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=
none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled
set wlan1 comment=“” manual-tx-powers=“1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,
0,HT40-0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0”
