I want to replace a OpenWRT router by RB4011 one. Actually I have this setup in my home:
From ONT goes 1 wire to the P1 of my OpenWRT router and other wire from P4 of the router to the P1 of the switch. This is the port configuration on the router:
The objetive of the configuration is to configure a PPPoE client in the P1 of the router and send the ONT VLAN to the switch P4 to connect a IPTV device.
I read about the VLAN modes in Routerboard, but I don’t know how to configure it. Anyone could help with this configuration? How could I configure the bridge?
My advice is not use vlan1, just change this to 10.
Why untagged vlan 30 on the ethernet interface with the ont??
I have an ont and a vlan for internet I didnt have to tag or untag anything, the vlan is associated with the ethernet interface period. Nothing more needs to be done.
Because @zorrua wants to pass WAN to IPTV device transparently (i.e. in switched manner) and he’s using VLAN30 (on the link between router and switch) for that. ONT delivers it untagged and IPTV device wants it untagged as well. @zorrua is using VLAN1 for normal LAN subnet.
@zorrua: what you need is not complicated at all and reading article @anav linked should help you understand VLAN on ROS pretty well. Many users around here could spit the needed config for you, but we’re keen to teach newcomers how to catch the fish.
