Dear Board,
I have one RB2011Ui AS-RM (tested with RouterOS 6.7 + 6.11 + 6.12 ) and I like to configure some VLANs. It's the first time I try to use the Mikrotik Switch CPU because I'm interested in the wire speed performance. Now I discovered a strange phanomenon, hopefully someone could retry my configuration.
Objective:
I like to have untagged VLAN ports: ether3 (switch1) and ether9 (switch2), and I like to ping a special management IP address from that ports.
Configuration:
[admin@bkw] > interface ethernet print
Flags: X - disabled, R - running, S - slave
NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1-master 1500 D4:CA:6D:0B:A4:0F enabled none switch1
1 S ether2-slave 1500 D4:CA:6D:0B:A4:10 enabled ether1-master switch1
2 S ether3-slave 1500 D4:CA:6D:0B:A4:11 enabled ether1-master switch1
3 S ether4-slave 1500 D4:CA:6D:0B:A4:12 enabled ether1-master switch1
4 RS ether5-slave 1500 D4:CA:6D:0B:A4:13 enabled ether1-master switch1
5 R ether6-master 1500 D4:CA:6D:0B:A4:14 enabled none switch2
6 S ether7-slave 1500 D4:CA:6D:0B:A4:15 enabled ether6-master switch2
7 RS ether8-slave 1500 D4:CA:6D:0B:A4:16 enabled ether6-master switch2
8 S ether9-slave 1500 D4:CA:6D:0B:A4:17 enabled ether6-master switch2
9 S ether10-slave 1500 D4:CA:6D:0B:A4:18 enabled ether6-master switch2
10 sfp1 1500 D4:CA:6D:0B:A4:0E enabled none switch1
[admin@bkw] > interface vlan print
NAME MTU ARP VLAN-ID INTERFACE
0 R vlan-100-ether1 1500 enabled 100 ether1-master
1 R vlan-100-ether6 1500 enabled 100 ether6-master
[admin@bkw] > interface bridge print brief
NAME MTU
0 R switch1-switch2-master 1500
[admin@bkw] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 vlan-100-ether1 switch1-switch2-master 0x80 10 none
1 vlan-100-ether6 switch1-switch2-master 0x80 10 none
[admin@bkw] /ip> address print
ADDRESS NETWORK INTERFACE
0 192.168.27.254/24 192.168.27.0 switch1-switch2-master
[admin@bkw] > interface ethernet switch vlan print
SWITCH VLAN-ID PORTS
0 switch2 100 ether9-slave
switch2-cpu
1 switch1 100 ether3-slave
switch1-cpu
[admin@bkw] > interface ethernet switch port print
Flags: I - invalid
NAME SWITCH VLAN-MODE VLAN-HEADER DEFAULT-VLAN-ID
0 sfp1 switch1 disabled leave-as-is auto
1 ether1-master switch1 secure always-strip 10
2 ether2-slave switch1 disabled leave-as-is auto
3 ether3-slave switch1 secure always-strip 100
4 ether4-slave switch1 disabled leave-as-is auto
5 ether5-slave switch1 disabled leave-as-is auto
6 ether6-master switch2 secure always-strip 10
7 ether7-slave switch2 disabled leave-as-is 0
8 ether8-slave switch2 secure always-strip 100
9 ether9-slave switch2 secure always-strip 100
10 ether10-slave switch2 disabled leave-as-is 0
11 switch1-cpu switch1 disabled leave-as-is auto
12 switch2-cpu switch2 disabled leave-as-is 0Problem:
If I connect my laptop (192.168.27.9/24) to ether9 => I can ping 192.168.27.254. ![]()
If I connect my laptop (192.168.27.9/24) to ether3 => I can't ping 192.168.27.254. ![]()
I tried also to bind the management IP address on ether1-master or vlan-100-ether1 but the behaviour doesn't change.
IMHO everything for switch2 should also work with switch1, but it doesn't. I can't see any misconfiguration in my configuration.
Maybe someone could point out my mistake or retry and validate if there is a bug?
Sebastian
