Untangle Firewall
One of my client wants to run the Untangle Firewall on RouterBoard.
Is that possible?? and if yes which one to use??
-sid
Only thing that you can do is somehow configure metarouter on your router and there run a different OS with your firewall.
In RouterOS itself no 3rd party software is allowed
not third party but by removing RouterOS and reinstalling Untangle.
This OS runs only on X86 platforms: http://wiki.untangle.com/index.php/Hardware_Requirements
So, no, you can’t run it on RouterBOARD
thanx Normis… i will convey the same to the client.
I wish the Mikrotik supported it. It is a Linux Derivative.
