up and down
Hello Mikrotik
im using 5.2 and i got this logs :open_mouth: the rb750gl connect to a ordinary Ethernet switch hub (intex brand), why i got this problem its only a normal hub i think this is a port flap. but if i direct connect the laptop to rb it work!!. can i downgrade to 4.17 possible?
17:32:22 interface,info ether5-local link down
17:32:37 interface,info ether5-local link up (speed 10M, full duplex)
17:33:34 interface,info ether5-local link down
17:33:47 interface,info ether5-local link up (speed 10M, full duplex)
17:33:48 interface,info ether5-local link down
17:34:23 interface,info ether5-local link up (speed 100M, full duplex)
17:34:26 interface,info ether5-local link down
17:34:32 interface,info ether5-local link up (speed 100M, full duplex)
17:34:33 interface,info ether5-local link down
17:34:39 interface,info ether5-local link up (speed 10M, full duplex)
17:34:40 interface,info ether5-local link down
17:34:41 interface,info ether5-local link up (speed 100M, full duplex)
17:34:42 interface,info ether5-local link down
17:34:48 interface,info ether5-local link up (speed 100M, full duplex)
17:34:49 interface,info ether5-local link down
17:34:54 interface,info ether5-local link up (speed 10M, full duplex)
17:34:55 interface,info ether5-local link down
17:34:57 interface,info ether5-local link up (speed 100M, full duplex)
17:35:00 interface,info ether5-local link down
17:35:07 interface,info ether5-local link up (speed 100M, full duplex)
17:35:08 interface,info ether5-local link down
17:35:11 interface,info ether5-local link up (speed 100M, full duplex)
hi
please send Ethernet detail’s.
Hi this is just only a default interfaces config.
[myron@Boracay Gems] /interface> export
jan/01/2012 20:06:52 by RouterOS 5.2
software id = xxxx-xxxx
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=
00:0C:42:A1:FF:E2 master-port=none mtu=1500 name=ether1-local speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=
00:0C:42:A1:FF:E3 master-port=none mtu=1500 name=ether2-local speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=
00:0C:42:A1:FF:E4 master-port=none mtu=1500 name=ether3-local speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=
00:0C:42:A1:FF:E5 master-port=none mtu=1500 name=ether4-local speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1598 mac-address=
00:0C:42:A1:FF:E6 master-port=none mtu=1500 name=ether5-local speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set ether1-local vlan-mode=disabled
set ether2-local vlan-mode=disabled
set ether3-local vlan-mode=disabled
set ether4-local vlan-mode=disabled
set ether5-local vlan-mode=disabled
set switch1_cpu vlan-mode=disabled
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460
mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60
mac-address=FE:E5:08:A8:DA:92 max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460
max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=default enabled=no keepalive-timeout=60
max-mru=1500 max-mtu=1500 mrru=disabled port=443 verify-client-certificate=no
i see this post http://forum.mikrotik.com/t/new-ethernet-port-flap-issue-enquiery-pls-join/49200/1 that has an issue of port flapping, im stuck now in this problematic port flap situation please mikrotik team give me some solutions i have lots of mikrotik box to deploy sooner i don’t want my customer pissed in front of my face :frowning:
@Toiletbowl
If your RB works fine connected to your laptop, and there is a issue when connected to switch, the answer is only one:
Change your switch and buy something better than ‘Intex’.
HTH,
I’ve had some customers experiencing ‘slow’ Internet connectivity with specific types of dsl or docsis modems. Strangely, the same hardware works fine in 4.17 but not in 5.x.
@ditonet
i try to change dlink switch same issue dude and also i borrow cisco SF 300-24P same as well.
Happy New year
I have some routerboards hooked to cisco gear that do the same thing.
4.17 does not have interface state logging. So of course 4.17 is “better” as it does not show these events to occur. You can ignore them in 5.x releases and it will be just the same as it was in 4.17.
They weren’t experiencing interface flapping, they just said throughput was slower with v5. I haven’t verified it and I don’t know if it’s related to the problem being discussed here, but I thought I’d pitch in since it sounds similar
Hey mikrotik
i have a big trouble now i downgrade to 4.17 due of those 5.x version has an issue of port flapping after reboots my new RB750GL is no longer accessible ohhh myyyy please help what should i do im really disappointed now!!! :open_mouth:
