i am trying to update the os in rb750 v3.29 to v4.1 but its not working now i am trying to downgrade to original v3.29
But my bad luck i am not able to found v3.29 os
Can anyone help me to download v3.29 for rb750
don’t downgrade, it’s recommended to keep using RouterOS v4.10
Thanx for your reply sir,
But my problem now is i am not able to access the router from ip and as well as MAC
router is rebooting each few second I guess it looking for boot loader and when i run netinstall it is not rebooting
i try to update v4.1 again and again but the problem is same after updating.
waiting reply
Thanx,
Rakesh
Still Wait…ing Reply…
Did you try to upgrade to different versions like 4.0, 4.5 or 4.10?
Did you upgrade firmware on 3.29?
thax again for reply,
i tried update 3.29 to 4.1 and faced trouble to accessing the router and offcourse as u say i try 4.1 and 3.1 but stil same …
can someone lead me to download routeros 3.29… pls…
Rakesh
try to use other psu … at lest 12V1A
Still the same problem can anyone help me …?
plsssssssssssssssss…
It’s rebooting every few seconds? What’s setup in your watchdog entry?
Instead of trying to upgrade/downgrade, reset the unit back to defaults and try programming it again. Sounds like it’s an errant configuration (or a power supply issue like vacarosie200 mentions) more than a firmware problem.
How did you upgrade your firmware to 4.10? Did you use the WinBox drag&drop function? And did you make sure you only dropped the .npk package (download link for .npk file for your model http://download.mikrotik.com/routeros-mipsbe-4.10.npk).
I just did on my RB493AH board today, and works perfectly! I can only recormmend the 4.10 version, since it have a lot of features that 3.xx doesn’t have.
aaaaha.. finallyy its worked..!!! thanky everybody for helping Thankuuuu…very much
Rakesh
i think it will be nice from you to tell us how you fix it
