Hey guys,
I’ve got a little bit of a problem. I’ve installed 2.9.27 onto a HDD that had 2.8.26 with a valid key on it, told it to not keep the old configuration.
After logging in on the console, it says:
ROUTER HAS NEW SOFTWARE KEY
Your router has a valid key, but it will become active only after reboot. Router will automatically reboot in a day.
/sys reboot doesn’t fix it
and /sys lic update-key and /sys lic new-upgrade-key both tell me:
“Failed to set new key (invalid key (6))”
I didn’t see any mention of this error message here:
http://www.mikrotik.com/docs/ros/2.9/system/license
And I can’t seem to upgrade this key to 2.9 thru the MikroTik website.
Any Ideas?
I just tried it in WinBox; the only difference is when I try “Update Key”, it tells me “Could not change the key - invalid key”.
WinBox does say it’ll expire in 2d 22:38:18.
