I am trying to upgrade a router from 6 to 7. I had hopes that I could simply copy and paste the configuration in sections. As an example, when I open a terminal in V7, go to /ip firewall filter and paste the following config:
/ip/firewall/filter> add action=drop chain=input dst-port=22 protocol=tcp src-address-list=\ssh_blacklis
[Safe Mode taken]
line 3 of 3> MCPA( B/A
I don’t know why it is hammering the end of my text, but this will make a very long process if I have to type all the code in on every router by hand and troubleshoot all of the syntax errors that will certainly ensue.
Usually it is as simple as upgrade to ROS7 and that’s it.
Config is being upgraded automagically for most parts.
So start from a working ROS6 config.
Upgrade your device.
Check config for missing parts (which normally should not be the case, except maybe for some fancy routing stuff).
That’s not what you said in the first post.
You said you were upgrading a router from 6 to 7.
So I conclude now you are moving config from ROS6 router to another ROS7 router ?
That’s something else.
If the new device came with ROS7, you cannot go back to 6.
Some things have changed from ROS6 to ROS7 on command line but not that much.
But obviously you need to start with a clean export from ROS6.
How did you do that ?
“Export terse” should take care of the line breaks. Otherwise you need to pre-process the script first with a txt editor.
The “new” shitpad on windows 11 when copy text on memory transform the text in something… different…
When you paste that shit on terminal, all is ruined…
