Update DynDNS
New to Mikrotik world.
Trying to setup a DynDNS update script in RB951Ui-2HnD with 6.31 OS. The script I use is the next:
:local ddnsuser DYNDNSUSERNAME // change this with your dyndns username
:local ddnspass DYNDNSPASSWORD // change this with your dyndns passowrd
:local theinterface PPPoE-INTERFACE // change this with your PPPoE client name
:local ddnshost DYNDNSHOSTNAME // change this with your dyndns hostname
//DON’T CHANGE ANYTHING BELOW THIS LINE
:local ipddns [:resolve $ddnshost];
:local ipfresh [ /ip address get [/ip address find interface=$theinterface ] address ]
:if ([ :typeof $ipfresh ] = nil ) do={
:log info (“DynDNS: No ip address on $theinterface .”)
} else={
:for i from=( [:len $ipfresh] - 1) to=0 do={
:if ( [:pick $ipfresh $i] = “/”) do={
:set ipfresh [:pick $ipfresh 0 $i];
:if ($ipddns != $ipfresh) do={
:log info (“DynDNS: IP-DynDNS = $ipddns”)
:log info (“DynDNS: IP-Fresh = $ipfresh”)
:log info “DynDNS: Update IP needed, Sending UPDATE…!”
:local str “/nic/update?hostname=$ddnshost&myip=$ipfresh&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG”
/tool fetch address=members.dyndns.org src-path=$str mode=http user=$ddnsuser
password=$ddnspass dst-path=(“/DynDNS.”.$ddnshost)
:delay 1
:local str [/file find name=“DynDNS.$ddnshost”];
/file remove $str
:global ipddns $ipfresh
:log info “DynDNS: IP updated to $ipfresh!”
} else={
:log info “DynDNS: dont need changes”;
replacing of course with my credentials. The script runs but the ip is not updating
The same script in 6.29 was working just fine .
What should I do now to fix this ?
Me too. Waiting for someone …
here is working script, found here on forum
working for me at 6.32
# Based on a script found on the Internet.Will add attribution if I find it.
# Changed 20150719 by Graeme Ruthven (graeme@kula.co.nz)
# Modified to:
# - update using authentication in URL as original method appeared to stop working.
#   This was about the time of the RouterOS 6.30 release, but may be unrelated.
# - Get the previous IP from the contents of the dyndns.txt file, as the global variable
#   doesn't appear to persist.
# Reference: https://help.dyn.com/remote-access-api/perform-update/
:local username xxxxx
:local password  xxxxxx
:local hostname xxxx.dyndns.tv
:local emailAddress xxxxx@gmail.com
:local url "dummy"
:local previousIP
:global dyndnsForce
:set dyndnsForce false
:log info ("UpdateDynDNS starts.")
# print some debug info
#:log info ("UpdateDynDNS: username = $username")
#:log info ("UpdateDynDNS: password = $password")
#:log info ("UpdateDynDNS: hostname = $hostname")
#:log info ("UpdateDynDNS: previousIP = $previousIP")
# I have some doubt over the persistence of the global previousIP.
# This value should be stored in /dyndns.txt after the last update attempt,
# preceded by the status and a space.
# For status values see: https://help.dyn.com/remote-access-api/return-codes/
:if ([:len [/file find name=dyndns.txt]] > 0) do={
   :local ipfile [/file get dyndns.txt contents]
   :local ipstart ([find $ipfile " " -1] + 1)
   :local ipend [:len $ipfile]
   :set previousIP [:pick $ipfile $ipstart $ipend]
} else={
   :set previousIP "0.0.0.0"
# get the current IP address from the internet (in case of double-nat)
/tool fetch mode=http address="checkip.dyn.com" src-path="/" dst-path="/dyndns.checkip.html"
:delay 1
:local result [/file get dyndns.checkip.html contents]
# parse the current IP result
:local resultLen [:len $result]
:local startLoc [:find $result ": " -1]
:set startLoc ($startLoc + 2)
:local endLoc [:find $result "</body>" -1]
:local currentIP [:pick $result $startLoc $endLoc]
# Remove the # on next line to force an update every single time - useful for debugging,
# but you could end up getting blacklisted by DynDNS!
#:set dyndnsForce true
# Determine if dyndns update is needed
# more dyndns updater request details http://www.dyndns.com/developers/specs/syntax.html
:if (($currentIP != $previousIP) || ($dyndnsForce = true)) do={
   :log info ("Changing IP from $previousIP to $currentIP.")
   :set url "http://$username:$password@members.dyndns.org/nic/update?hostname=$hostname&myip=$currentIP&wildcard=no"
   /tool fetch url=$url mode=http dst-path="/dyndns.txt"
# Original code:
#   /tool fetch user=$username password=$password mode=http address="members.dyndns.org" \
#      src-path="nic/update?system=dyndns&hostname=$hostname&myip=$currentIP&wildcard=no" \
#      dst-path="/dyndns.txt"
   :delay 1
 #  :set previousIP $currentIP
   :local result [/file get dyndns.txt contents]
   :log info ("UpdateDynDNS: Dyndns update needed")
   :log info ("UpdateDynDNS: Dyndns Update Result: ".$result)
# email result:
   :local output "DynDNS Update Result: $result"
   /tool e-mail send to="$emailAddress" subject="DynDNS update $currentTime" body="$output"
} else={
   :log info ("UpdateDynDNS: No dyndns update needed")
