UPDATE FIRMWARE
Friends,
Every time a firmware update comes out in mikrotik, is it recommended to do it to the RB? Another thing is what type of firmware is more advisable to update, stable or testing?.
Thank you for your recommendations.
ELDONCITO.
Every time you do an update you won’t know what you are updating with. It could be new but it could be also a existing version and only the version number is changed.
Only Mikrotik knows if there are changes.
It very inpolite to SHOUT, do you know that?
I would only use “stable” or “long term” for routers that you use in production.
For each release, you can read about what Mikrotik has fixed / improved, BUT it might also introduce other issues.
For security reasons I would keep your RB pretty much up to date and regularly check if there are security advisories because of found vulnerabilities or something.
But finally, ask yourself if everything is working fine with the features you use. Don’t upgrade for the sake of upgrade unless you accept the fact that you could suddenly start getting issues…
There are detailed changelogs available for both Stable and Testing branches, you can see exactly what you are upgrading.
https://mikrotik.com/download/changelogs
Also, I suggest to keep router updated at all times, “Stable” branch would be the best.
