Update from CapsMan to AccessPoints
Hello together,
I have some MikroTik Routers CRS354-48G-4S+2Q+ (mipsbe) and cAP ac Acces-Points for Wireless Lan.
One of this Switches are the Capsman Server for manage the Access-Point, thats fine and run great. But now i try Upgrade the Firmware of the AP’s over the Capsman Switch to send it to all AP’s.
Problem is they doesnt upgrade, but why.
Switch Router OS: v.6.49.3 (stable)
AP’s Router OS : v6.49.2 (stable)
A newer Firmware v.6.49.3 (arm Package )is in Flash Folder , the Path is registered in Capsman Manager. The AP’s turn on Upgrade but after reboot they have Skiped the Update with this Message:
should auto upgrade, but skip as tried already, provision as same version only suggested
Thats the Log
[2C:C8:1B:3B:09:A2/7/8b04,Run,[2C:C8:1B:3B:09:A2]] should auto upgrade
[2C:C8:1B:3B:09:A2/7/8b04,Run,[2C:C8:1B:3B:09:A2]] ask to upgrade, version 6.49.3
[2C:C8:1B:3B:09:A2/7/8b04,Run,[2C:C8:1B:3B:09:A2]] upgrade status: rebooting, disconnect
[2C:C8:1B:3B:09:A2/7/4564,Run,[2C:C8:1B:3B:09:A2]] should auto upgrade, but skip as tried already, provision as same version only suggested
Do you have any idea whats wrong ore can it be thats the Router OS is (mipsbe) and the AP’s OS (arm) ??
Thx for our help.
Kind regard’s Mario
