I’m setting up a private repository with a few specific RouterOS versions, to be used by our routers (half a dozen RB2011’s, about 40 hAP lites, and a few hAP ac’s.)
I’ve been reverse-engineering the mechanism behind the “/system package update” mechanism, and I’ve reached the point where my test router is downloading and installing the packages from my internal web server. However, even after rebooting into the new version, “/system package update check-for-updates” says that a new version is available, even though I haven’t changed anything on the web serer.
[admin@MikroTik] /system package update> print
channel: current
installed-version: 6.34.2
latest-version: 6.34.2
status: New version is available
The only thing I can figure is that the timestamp in the “/LATEST.6” file is being compared to a value embedded within one of the packages, and I don’t have the correct timestamp value within the “/LATEST.6” file.
Is there a way to find out what the correct value should be for each release? Obviously I have the correct value for 6.38, but that timestamp doesn’t seem to match up with anything obvious. Is there maybe a list of the correct values out there?
