Update my provider arp cache
How can I update my provider’s arp cache?
If I change some interfaces, it takes a lot of time to update my provider’s arp cache. When using linux I used to type something like:
echo 1 > /proc/sys/net/ipv4/ip_nonlocal_bind
arping -U -I vlan100 -c 10 -s MYPROXYARPPED_ADDRESS MY_ISP_GATEWAY
echo 0 > /proc/sys/net/ipv4/ip_nonlocal_bind
This way I could update theirs address… I cannot find something similar in mikrotik. Last time I had to phone them to “clear arp-cache” on their cisco routers…
I want to find a way to send unsolicited arpings… Any clue?
Anyone there ?
Can’t believe there is not arping -U or something similar !
Hello, it may be a few years after your post, however I needed to do a similar thing and found the following script at http://wiki.bluecrow.net/index.php/Mikrotik#Clearing_the_arp_cache
:log info "clearing arp table of dynamic entries"
:local counter 0
:local delaytime 5
:local numloops 12
:while ($counter < $numloops) do={ \
:log info "clearing arp loop"
:foreach i in=[/ip arp find dynamic=yes] do={
/ip arp remove $i
:log info "delaying..."
:delay $delaytime
