Hello, i have a problem with my new RB493G and i’m out of my own “guesses”, so hope someone help me here.
After first boot, i removed default configuration and set everything as i wanted. Everythig was fine until i plug the uplink cable. I have a WAN port set to Eth2 (because Eth1 is from the side, but all cables going behind the cabinet, so its easier to use another port). The main problem is, the WAN port going UP and DOWN over and over. This is part of the log:
18:24:34 interface,info 2_Uplink link down
18:24:35 interface,info 2_Uplink link up (speed 100M, full duplex)
18:24:36 interface,info 2_Uplink link down
18:24:37 interface,info 2_Uplink link up (speed 100M, full duplex)
18:24:38 interface,info 2_Uplink link down
18:24:42 interface,info 2_Uplink link up (speed 100M, full duplex)
18:24:44 interface,info 2_Uplink link down
18:24:45 interface,info 2_Uplink link up (speed 100M, full duplex)
18:24:48 interface,info 2_Uplink link down
18:24:52 interface,info 2_Uplink link up (speed 100M, full duplex)
18:24:57 interface,info 2_Uplink link down
18:24:59 interface,info 2_Uplink link up (speed 100M, full duplex)
and over and over like this. I thought that i have somewhere some conflict, co i disabled all ports except WAN (Eth2), me (Eth3) and one more station (Eth6). To be sure, i disabled all NAT and FW rules and IGMP proxy. I keep active Bridge, DHCP client for WAN and DHCP server for the bridge. Unfortunately, still the same issue.
LAN connects:
Eth1 - nothing
Eth2 - WAN
Eth3 - Station (me)
Eth4 - Station (Off)
Eth5 - Station (Off)
Eth6 - Station (ON)
Eth7 - nothing
Eth8 - WiFi router (temporary, until miniPCI card arrive, also Off during the test)
Eth9 - NAS (Off)
Ports 3,4,5,6 are in BRIDGE
I was worried about the physical port can be broken, so to be sure, i changed the configuration. I set the Eth1 as WAN port and i added Eth2 to the existing bridge. Then i connect via Eth2. It was a supprise that everything was OK, no port up/down cycles, speed on 1000BaseT full duplex. But then, after few seconds, Eth6 (where another machine was conencted) start “cycling” in “UP/DOWN”.
So i start checking every configuration, because that was odd, and i found one possible cause of this problem in SWITCH setting.
NAME SWITCH VLAN-MODE VLAN-HEADER
0 1_Free > switch1 > fallback leave-as-is
1 2_WAN > switch2 > fallback leave-as-is
2 3_aaa > switch2 > fallback leave-as-is
3 4_bbb > switch2 > fallback leave-as-is
4 5_ccc > switch2 > fallback leave-as-is
5 6_ddd > switch1 > fallback leave-as-is
6 7_Free > switch1 > fallback leave-as-is
7 8_WRouter > switch1 > fallback leave-as-is
8 9_NAS > switch1 > fallback leave-as-is
9 switch1_cpu > switch1 > fallback leave-as-is
10 switch2_cpu > switch2 > fallback leave-as-is
Basicly, port which is on the same switch as WAN port failing, or the wan port failing.
I didn’t find any way how to turn off the switch, because i don’t need to use this (not now, maybe latter).
So can anyone please help me how to set things up to work properly? (I need keep the bridge set because of some FW/NAT rules.)
Thanks a LOT for any usefull info
BTW: I can set a guest account, if needed.
//EDIT: CPU overload solved.
