Update to 3.11... Kernel Panic!!
Hi, I’ve tried to update from 3.10x86 (PIII 800 - MB supermicro) to 3.11 but SURPRISE!!
“Loading system with initrd
uncompressing linux… ok. Booting the Kernel
execve 00000002
kernel panic - not syncing - attempted to kill init”
What happens?
Paolo
have you tried to reinstall it? (netinstall, cd installation to save license and configuration)
Hi Janisk,
I’ve re-installed 3.10 from CD (keep config) and router now work… You think the problem came only when I update my router?
I can try to reload 3.11 from CD and restore saved configuration…
if you can, please try ftp update again, if that fails, than 3.11 cd installation.
ok… wait…
..Work!!!
Bah! Why the error at the first attempt?
And in 3.11 there isn’t “restore” key in files box… where is it?
restore backup from command line, the button will be back in 3.12
HeHe!!! The button gone in vacation? I hope he happy. :laughing:
