Hi there!
I mentioned this in another post but got no response so far.
Since its bugging me Id like to dedicate a seperate post to it. Ive upgraded one of my CCR2004 routers from 7.12 to 7.14 and after the Update one of my VRFs was renamed: an underscore got appended.
Previously it was named VRF_EXT now its called VRF_EXT_
I cant rename it back since i get the message that:
“failure: device with the same name already exists VRF_EXT”
/ip vrf print however only shows two vrfs and none of them is named VRF_EXT.
I tried to rename with this command:
/ip vrf set [/ip vrf find name=VRF_EXT_] name=VRF_EXT
And i tried to rename through the gui as well but same error.
How to fix this?
