Sorry i have this noob question .
I am a bit confused by RouterOS update process..:
So the “Check for Updates” section in the quick set panel shows me the installed version is 6.49.7, but on the routerboard panel it shows 6.47.10 as the current firmware..
So i guess that means the OS and the Firmware are independent right? I understand if i click the UPGRADE button in Routerboard the firmware then shows updated…
I always though the update took care of everything but looks like i was never upgrading the firmware. Does this mean the router was always exposed to the existing security holes
with the previous versions or the updates alone take care of that regardless of the firmware installed?
@axotik
RouterBOOT = firmware = “BIOS / EFI” (for other user that currently do not are on this topic: no matter the precise and correct scientific name)
RouterOS = software (like Ubuntu / Windows / MacOS)
You can have different versions, but is important to have latest firmware/RouterBOOT,
because if you read the changelogs, often some fix are possible only if laters RouterBOOT/firmware is used.
For examples, latest RouterOS changelogs: (not exist one RouterBOOT changelog, but is like this, at the end)
7.6
*) routerboard - set “Delete” as default key to enter booter menu (> “/system routerboard upgrade” required> );
*) routerboard - fixed memory test on CCR2116-12G-4S+ (> “/system routerboard upgrade” required> );
*) routerboard - improved RouterBOOT stability for Alpine CPUs (> “/system routerboard upgrade” required> );
MikroTik, from version 6 onwards, has taken on the bad and detestable habit of calling the firmware with a new name every time,
even if absolutely nothing changes inside.
Ok thank you guys for the clarifications..
Now i have another router. A hAP AC2 with up to date 6.49.7 OS/Firmware.
I downloaded the available upgrade here in the product page: https://mikrotik.com/product/hap_ac2#fndtn-downloads
So i got the file: routeros-arm-7.9.npk
I uploaded the file to the mikrotik router and typed:
Immediately a new text file showed up in the root of the disk with the following:
# may/18/2023 17:27: 9 by RouterOS 6.49.7
# software id = LNA4-IPRD
channel: stable
installed-version: 6.49.7
latest-version: 6.49.7
status: System is already up to date
So it looks like the router is not upgrading to 7.9.
From screenshot, you use winbox…
On drop-down menu select upgrade (7.9) and click download and install (at your own risk)
or simply drag & drop file on open winbox (without any windows opened inside) and reboot without check if the file is visible or not.
