Had a strange issue with my RB5009. I updated it from 7.4 to 7.10 a couple weeks ago, and out of the blue now it give this error when I attempt to login via ssh:
kex_exchange_identification: Connection closed by remote host
I can get in fine with winbox using the MAC address, but no ssh. I do have a rule blocking ssh,winbox and port 80 from the WAN interface (ether1) but that shouldn’t be blocking me from the internal LAN. When I try from webfig I get: “ERR_CONNECTION_RESET”.
Has anyone run into this? I can share the config if needed, but it has worked fine for about 2 years with no issues on 7.4. I did let it update to 7.11 this morning with no change. I have rebooted it twice hoping it was just some glitch with the updates.
In summary my issue wasn’t out of the blue it turns out, apparently I have never tried connecting from the “user” network from the office here, I normally go in from the management vlan or the trusted vlan, and this time it bit me! All good now! and yes, I’m an idiot!! lol
Thank you erlinden for the fast reply, much appreciated!
Order your firewall rules (especially when shared your Mikrotik friends on the forum), that (appart from the missing rule below) will make it more readable and maintainable.
