Following on this old post: http://forum.mikrotik.com/t/updating-ca-root-certs-regularly/144990/1
My version looks like this but generates the error every other run. I run it once, it fails (i.e. it writes the error to the log), run it again and it passes (i.e. it writes the success message to the log). If I manually enter the commands they work fine on their own. Any reason why it would fail 50% of the time?
:do {
/tool fetch url=https://pki.goog/roots.pem dst-path=roots-goog.pem;
/certificate remove [ find where authority expired ];
/certificate import file-name=roots-goog.pem passphrase="";
/file remove roots-goog.pem;
:log info ("Updated certificate trust store");
} on-error={
:log error ("Failed to update certificate trust store");
