Hi everybody,
the command system license print shows th following:
software-id: "IAIK-M83J"
upgradable-to: (unknown)
nlevel: 4
features:
What does this mean?
Fux
Hi everybody,
nlevel: 4
features:
Fux
Still got this problem.
Does nobody (even from Mikrotik) now a solution?
install newer version of RouterOS, one day you will see the version you can upgrade your router to.
also, if you are worried about this, send supout rif file to support.
