UPGRADE Cube to Level for PTMP ability
CubeG-5ac60ad
Is it possible to upgrade the OS to Level 4 so I can run a PTMP system.
Would I purchase the Level 4 license and then use Netinstall to upgrade or is there a way to upgrade the license without Netinstall.
Thx
Rick
Love answering my own questions.
1.Copied the Software ID in System → license
2. I went to the mikrotik.com site. Logged in.
3. Purchased a level 4 Key. ($45)
4. Copied the Key off the order details.
5. Pasted the key into the unit under System → License
Thanks for thinking kind thoughts.
Rick
How well does it operate as PtMP? Seems it would be a very narrow beam.
Would also like to know how well this cubes works as PtMP AP:s. :wink:
/Patricio
