I am running an wAP ac in a capsman setup. It was running perfect with router os 6.40, I was able to see the device in the winbox search list and could connect to it. Some days ago I did an upgrade to router os version 6.42.6. Afterwards everything was working except the neighbour discovery. When I start winbox all my devices are visible except the one I just upgraded to 6.42.6. Winbox version is 3.16.
When I do a direct connect by typing the IP in winbox I am able to connect. Below I have exported my config. in my opinion the neighbor discovery settings are all fine… In the “Neighbor List” menu when I am connected to the wAP ac all devices are visible. On the local pc winbox does not show the wAP ac… Any idea what is wrong here?
add fast-forward=no name=cap_bridge protocol-mode=none
/interface wireless
# managed by CAPsMAN
# channel: 2432/20-eC/gn(30dBm), SSID: , CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik
# channel: 5200/20-eCee/ac(17dBm), SSID: , CAPsMAN forwarding
set [ find default-name=wlan2 ] ssid=MikroTik
/interface vlan
add interface=cap_bridge loop-protect-disable-time=0s name=\
"bridge_vlan1__ Heimnetz" vlan-id=1
"bridge_vlan100_Guest WLAN" vlan-id=100
"bridge_vlan200__ PV" vlan-id=200
bridge_vlan300_Test vlan-id=300
"bridge_vlan400_SmartHome " vlan-id=400
bridge_vlan500_IPv6 vlan-id=500
add exclude=dynamic name=discover
add name=mac-winbox
/ip hotspot profile
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=cap_bridge hw=no interface=ether1
set discover-interface-list=mac-winbox
add interface=wlan1 list=discover
add interface=wlan2 list=discover
add interface="bridge_vlan1__ Heimnetz" list=discover
add interface="bridge_vlan1__ Heimnetz" list=mac-winbox
/interface wireless cap
set bridge=cap_bridge caps-man-addresses=192.168.0.254 certificate=request \
discovery-interfaces="bridge_vlan1__ Heimnetz" enabled=yes \
interfaces=wlan1,wlan2 lock-to-caps-man=yes
add address=192.168.0.211/24 interface="bridge_vlan1__ Heimnetz" \
network=192.168.0.0
set servers=192.168.0.254
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add distance=1 gateway=192.168.0.254
add distance=1 dst-address=192.168.0.254/32 gateway=\
/ip service
set telnet disabled=yes
set www address=192.168.0.0/24
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.0.0/24
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ipv6 nd
add hop-limit=64 interface=bridge_vlan500_IPv6
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Berlin
/system identity
set name=MkTkCapBasementAC
/system ntp client
set enabled=yes primary-ntp=192.168.0.254 secondary-ntp=192.168.0.254
/system routerboard settings
set silent-boot=no
/system upgrade upgrade-package-source
add address=192.168.0.254 user=user-auto-upgrade
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
