I recently upgraded my main home router from the hAP ac2 to hAP ax3. I have been using ROS for a while, but I do not change settings very often, so I am by no means an expert.
I cannot figure out what I did differently in this config than the previous (upgraded about 6 mo ago).
On the old router, I would print from my iPhone no prob, but with the new router, my iPhone just gives no air print printers found.
I can print from computers just fine and my GF can print from her Samsung phone as well (after I manually put in the IP).
Both the iPhone and the printer are on the same network (wifi 2.4gHz limitation of the printer). Using the old router, it did not matter as both the 2.4gHz and the 5gHz are in the same bridge. For some reason, the AirPrint packets are getting filtered out somewhere (I assume).
I am not knowledgeable enough to know if this is an error in my config, or if this is a bug with the new ROS 7 (hAP ac2 ran ROS 6).
My config is posted below. Please note that this is just what I have cobbled together using the default config and trying to customize for my needs (and learn).
I have been reading on the forum, but have not seen any issues like mine (again makes me think I did something wrong).
I have seen tons of posts about the how the hAP ax3 has bad wifi, but my experience has been incredible, other than this small issue. I get the full bandwidth of my service (600mb) in rooms near the router. In the near future, I plan to add a cAP ax on the other side of the house.
Feel free to pick this apart and let me know what I have done incorrectly. Thanks in advance for any advice.
# 2023-12-30 09:10:11 by RouterOS 7.13
# software id = 6AVW-UFWP
# model = C53UiG+5HPaxD2HPaxD
# serial number =
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-AcrossPasture
set [ find default-name=ether3 ] name=ether3-Office
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.country="United States" .manager=local .mode=ap \
.multicast-enhance=enabled .ssid=Computers disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac .width=\
20mhz configuration.country="United States" .manager=local .mode=ap \
.multicast-enhance=enabled .ssid="Game Consoles" disabled=no \
add configuration.mode=ap .multicast-enhance=enabled .ssid=Guest disabled=no \
mac-address=xx:xx:xx:xx:xx:xx master-interface=wifi1 name=wifi3
mac-address=xx:xx:xx:xx:xx:xx master-interface=wifi2 name=wifi4
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.15.50-192.168.15.200
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=xxxxxxxxxx
/interface bridge filter
add action=drop chain=forward in-interface=wifi3
add action=drop chain=forward out-interface=wifi3
add action=drop chain=forward in-interface=wifi4
add action=drop chain=forward out-interface=wifi4
add bridge=bridge comment=defconf interface=ether2-AcrossPasture \
internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether3-Office internal-path-cost=\
10 path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
add bridge=bridge interface=wifi3 internal-path-cost=10 path-cost=10
add bridge=bridge interface=wifi4 internal-path-cost=10 path-cost=10
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=all
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add comment=defconf interface=ether1-WAN list=WAN
add address=192.168.15.1/24 comment=defconf interface=bridge network=\
192.168.15.0
add address=xxx.xxx.xxx.xxx/xx interface=ether1-WAN network=xxx.xxx.xxx.xxx
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1-WAN
add address=192.168.15.0/24 comment=defconf dns-server=192.168.15.1 gateway=\
192.168.15.1 netmask=24
set allow-remote-requests=yes servers=xxx.xxx.xxx.xxx,xxx.xxx.xxx.xxx
/ip dns static
add address=192.168.15.1 comment=defconf name=router.lan
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1-WAN type=external
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add name=xxxxxxxxxx
/system clock
set time-zone-name=America/Chicago
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
