Upgrade from winbox 5.18
I have a RB750GL that is running Winbox v5.18 and I cannot work out how to get it up to 5.24. My other devices that are already 5.24 have the ‘check for updates’ option under System, but the v5.18 does not seem to have this. Can someone please point me in the right direction?
Download all packages zip file, extract the files you need, put them into router and reboot.
Thanks for the reply - do I need to put them in a certain location? What happens after I reboot?
