I want upgrade hw from RB750 without wifi to RB751 with wireless.
Is ok only backup to file on RB750, and restore from this file on other RB751?
If this not ok, what must do?
If you use v5.21, better use command “/export compact file=name” and then “/import name” This will work better
this is not good
i want all configuration, ip of router, admin password, interfaces ,…
this does give you all that
export is not set router IP
backup and restore not set wan ip route
sorry but you are not correct. export sets all settings you mentioned, including IP
i have 2 router
750g, working like a charm
and 751g with wifi
i want only to replace router with conf of 750g
and not work
OK, in RB750G type “/export compact file=name”. Then copy the file “name.rsc” to the other router. In the other router type “/import name.rsc” and see what happens. If nothing works, in RB751 type “/export compact” and paste output here.
import return:
failure: pool with such name exists
testing:
before import, i change ip address to 1.3 (original is 1.2)
and then import
and ip adress stay 1.3
manualy change to original 1.2
but nat is not working ?!?!
you can do this:
/system reset run-after-reset="name.rsc"it will clear current config, and then import the one from RB750
model 750
fw 2.41
model 751g
fw 3.0
dont work
reset is reseting router
run-after is not work (none conf from name.rsc)
when manualy import name.rsc (failure again, ip pool exists), routing conf is not visible
i thing that failure not execute all script
