Upgrade issues
Hi All!
I am receiving “ERROR: file not found” error when trying to check for updates:
[admin@Cerberus] > system resource print
             uptime: 16w6d5h55m4s
            version: 6.45.6 (stable)
         build-time: Sep/10/2019 09:06:31
   factory-software: 6.43.2
        free-memory: 959.9MiB
       total-memory: 1024.0MiB
                cpu: ARMv7
          cpu-count: 4
      cpu-frequency: 1400MHz
           cpu-load: 0%
     free-hdd-space: 421.0MiB
    total-hdd-space: 512.3MiB
  architecture-name: arm
         board-name: RB4011iGS+5HacQ2HnD
           platform: MikroTik
[admin@Cerberus] > system package update check-for-updates
            channel: stable
  installed-version: 6.45.6
             status: ERROR: file not found
[admin@Cerberus] > ping download.mikrotik.com
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 172.217.22.174                             56  50 64ms
    1 172.217.22.174                             56  50 47ms
    2 172.217.22.174                             56  50 44ms
    sent=3 received=3 packet-loss=0% min-rtt=44ms avg-rtt=51ms max-rtt=64ms
[admin@Cerberus] >
I have tried updating my other two RouterBoard devices (RBcAPGi-5acD2nD and RBD52G-5HACD2HND-TC), these failed with the same symptoms as well.
Starting the update check from the menu gives the same error.
Where should I look? What could be the problem?
Your DNS resolver (and possibly router) had been hijacked. Download.mikrotik.com has IP addresses (2 of them) in 159.148.0.0/16 network.
I see. From my office network it resolves correctly…
Added 8.8.8.8 and 8.8.4.4 before my ISP’s DNSs, rebooted and it works snow.
Thank you!
