Upgrade issues.
I’ve tried to update Mikrotik RB951G-2HD with the latest OS version 6.34.2
I don’t have any experience with Mikrotik.
Current firmware: 3.22
Current OS version: 6.27
Download ends with “ERROR: missing wireless-6.34.2-mipsbe.npk”
Any ideas?
Your help is highly appreciated.
Try a manual upgrade:
1.- Download 6.34.2 from http://download2.mikrotik.com/routeros/6.34.2/routeros-mipsbe-6.34.2.npk to your computer.
2.- Connect by winbox, then drag and drop the npk file over the winbox window.
3.- Wait for it to transfer, then reboot.
This is answer to your question:
What’s new in 6.33.5 (2015-Dec-28 09:13):
*) wireless - regular “wireless” package is now retired and replaced by “wireless-fp” and “wireless-cm2”;
This means that in update you are trying to do is the old wireless package missing - intentionally.
Therefore upload wireless-cm2 package to your router, activate it instead of old wireless package and everything should be fine for update after that.
