I have had a RouterBoard 751g-2HnD for a few months now. I am somewhat confused as to the upgrade path the numbers seem all over the shop. The Version I am using is 5.6 with a firmware version of 2.36 Could you clarify to me what upgrade patb there is.
RouterOS versions are numbered sequentially, when a period is used to separate sequences, it does not represent a decimal point, and the sequences do not have positional significance. An identifier of 2.5, for instance, is not “two and a half” or “half way to version three”, it is the fifth second-level revision of the second first-level revision. Therefore v5.2 is older than v5.18, which is newer.
