Upgrade Problem
Hi.
I tried upgrading my router and noe it doesn’t boot anymore!! Is there anything i can do?
Please help.
How u upgreaded..???
Using net Install..??? If yes..
Make Sure that “set the boot device back to IDE in the RouterBoard BIOS”
I draged and dropped the pakages to to “files” window, and then rebooted.
what do you see on the screen when it’s booting up?
It only makes one beep now, and not the two beeps telling me it has finished booting up. I only use and know winbox. If I scan on winbox, i dont get anything at all. It is a 112 routerboard.
Try again with Netinstall…
http://www.mikrotik.com/testdocs/ros/2.9/guide/netinstall.php
I actually d/l that, but it doesn’t see my routerboard either. Only my other two hard drives.
I’m thinking you want to read those instructions again…
connect via console cable and see what it says !
