Upgrade problem
maybe this isn’t a right place for this post but … i’m trying to install RouterOS 5.12 on a goove without any result.
i started from the 5.2 for passing directly to the 5.12, but nothing, so i’ve tryed from 5.11 to 5.12 (upgrading the fw before), and nothing again. (with 2 machines)
I also noted that version 5.12 is recognized in a different way from the 5.11 , as shown in the figure :
It’s normal?
Is there any workaround to installing 5.12 on groove?
Nope. Upload the file and reboot the device. I would try to upload the 5.12 package again because it should show up as a package. How are you trying to upgrade?
you are connected via MAC address. very bad idea. connect to IP address and it will work.
i’m going to try
