How to safe upgrade MT 1100AHx2 with RouterOS 6.0rc6 to the newest stable version? Could I just upgrade to 6.37.3? Or should I update step-by-step through specific versions?
Firmware version is 3.02. It’s one of the core routers, so I don’t want to make a mistake.
Thanks in forward!
Make a backup and an Export file, download them to your PC.
Then just upgrade as usual. It should work fine with direct drag/drop/reboot
Will do, thanks a lot normis!
