Hi there,
I’m wondering if I have additional packages installed on my RouterOS, for example, ZeroTier, Container.
If I want to upgrade my existing RouterOS 7.8 to 7.9, how can I upgrade the additional packages?
I was thinking upgrade the RouterOS, and then ZeroTier package, or can I do all of them at once (i.e. upload all the .npk files on the File section)
Cheers
When you use winbox / upgrade (System / Packages / Check for Updates - Download & Install or command line equivalent) the extra packages will be upgraded “automagically”
Yes, either you use “check for updates” and let the router download the packages, or when that isn’t possible (e.g. because the router has no internet connectivity) you check which packages you have and upload the same new version of everything (routeros-xxx and otherpackage-xxx) to the router and reboot.
I’ve managed to upgrade using the Packages menu, and yep all extra packages are upgraded automagically. Thanks team!
