upgrade the license to Level4,
i need to upgrade the license to Level4, my router sxt 2
Can I do that?
Yes. You’ll need to purchase it, handing the Device ID to the reseller, be it Mikrotik or a distributor.
Usually is more worthy to buy a new device which in your case, if you’re going to use it as AP for multiple devices, will bring another benefit: gigabit.
Bear in mind that to set up one PTP, you can set wireless mode of the “ap” end to bridge, and will allow for one station to connect, no need for L4 in that case.
I need 20 keys
I have 20 sxt 2
How can I buy?
Are you sure that you have no Level4 license ?
https://routerboard.com/RBSXTG-2HnD says that SXT2 is sold with Level4.
Maybe you have SXT2 Lite not full SXT2 ?
i have sxt2 lite 2
id:sxt 2nd r2
I need to upgrade the license to Level4,
I have 20 devices and need to be modified
Are you going to use these as APs for multiple customer devices or to build PTPs between them? What will be their use?
yes
If their role is to be a customer’s client you do not need to buy higher license at all.
I want to connect to the device more than one user
Now only one device
If they’re new and unopened, I would ask your provider for a change… you’re going to spend almost the same than buying new RBSXTG-2HnD units.
I cant
I would buy a key myself
Buy rather proper devices for that and use these elsewhere.
We are able to provide you the licenses. Contact us in private
I want his way to communicate with you
Of course, not problem
We have L4 licences at 29,99Eur/35US$ each one at today exchange rate.
Paypal payments accepted.
Normal stock price at distributor’s shelf including vat.
Good .. I want a workout key then I bought 20 keys
my whats app
00962777494273
