upgrade the router as it was a simple machine
I am just receiving my new router, an CCR1009 model.
As I am waiting for my sfp module, I would like to use this time to upgrade the firmware.
The ccr1009 is connected in my network like this:
internet —my_actual_router — switch — ccr1009
(192.168.1.1) (192.168.1.5)
(port:eth2)
I did:
quick set > mode bridge > addr. acq:static > ip addr: 192.168.1.5 > netmask:255.255.255.0 > gateway: 192.168.1.1 > dns server: 192.168.1.35
I pressed the “check fo update” button: error no internet connection
What is wrong in my config or what is missing ?
Thanks by advance
Apparently your internet connection is not working. You need to debug that.
E.g. use /tool ping to ping your other router and if that works ping 8.8.8.8 or similar.
Is there a default route?
why is dns server set to 192.168.1.35?
Why '35: because on the switch I have a DNS server and it’s working !
My internet connection is working: I am posting this message …
The others machines have access to internet.
/ tool ping 8.8.8.8 gives “no route to host”
ah ah …
/ route display for the first line: 0 xs 0.0.0.0/0 …
if I click on the x, the route becomes enable
Does it mean that the routes are always disabled by default ?
Bravo and thank you :slight_smile:
Of course I meant “no working internet connection from the CCR”, and indeed it wasn’t.
New entries are normally enabled but maybe you disabled it unintenionally.
