Upgrade to 2.9.5 = kernel panic
I just upgraded from 2.9.1 to 2.9.5 using single package. I’ve got “kernel panic. attemp to kill init” after restart.
Is there a way to rescue system and not loos the licence?
i am sure u wont loose the license if u re-install the MTOS with a bootable CD of any version u want. u can download the CD image from mikrotik site and install directly from CD
Yes, You’re right. I’ve reinstalled the router from CD and it’s OK now, but i wan’t upgrade any of my routers to 2.9.5 :confused:
i think you should wait for the next version , or try tu upgrade to 2.9.2 or 2.9.4
