i tried upgrade rb500 and rb133c and both are death now…
rb’s are instaled on 30 meter towers and now i must do what?
netinstall ?
this is problem i have about 80 rb133c, 15 rb500 in my network… all licensed to 3.x
can you explain that, why upgrade doesn’t work ?
config of rb is , bridging, wlan on 5ghz (cm9), routing?
Press any key within 1 seconds to enter setup.
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
------------------>8-----------------------
