I have a 1100ahx2 that came with version 5.14. I have checked that auto upgrade and it doesnt find any new versions or anything. I would like to upgrade it to version 6. I have downloaded it and and installed it in the main directory and rebooted and it still says version 5.14.
Any suggestions?
BACKUP ALL FIRST!!!
wait: before do anything at your own risk, read all first!
download both files:
http://i.mt.lv/routerboard/files/p2020_3.10.fwf
http://www.mikrotik.com/download/share/routeros-powerpc-6.11.npk
[thanks Normis for the link (http://forum.mikrotik.com/t/ipsec-ios-doesnt-work/75174/17)]
and drag with winbox in files folder [hint: remove first all unused]
be sure are not on sub-folder
paste this command on terminal, or with winbox go to system / routerboard and click on [upgrade] button,
/system routerboard upgrade
y
reboot the routerboard from system / reboot, not with disconnecting power,
you done.
After each new 6.x exit [if dns and wan are propperly configured],
you can use system / packages / check for updates
for the new software.
If I have helped you, please add Karma.
