Hi i have in my MK the version 2.9.42 if I Upgrade to the lastest version that is 2.9.48 can I have a problem with it or i must have to intall the version that was before the 2.9.48 …also how can upgrade mi mk
thanks
thanks
You can upgrade to the newest version directly.
thanks and how i do it i will apreciate your help thanks
Read the manual
just FTP the newest packages and reboot. the instructions are on the download page
thanks to all and my best regards
