Upgraded From 6.32.2 to 6.33.3....Basic Routing Now Broken?
Looking for some technical help. I upgraded my CRS125-24G-1S from 6.32.2 to 6.33.3, but now I can’t seem to route between some internal subnets.
As an example, from the CLI on the router, we have the following IP addresses on the router:
Router> ip address print detail
 0   ;;; Routed /30
     address=192.171.61.117/30 network=192.171.61.116 interface=br-vlan20 actual-interface=br-vlan20
 1   ;;; NAT Subnet
     address=192.168.1.1/24 network=192.168.1.0 interface=br-vlan10 actual-interface=br-vlan10
 2   ;;; Mgmt Subnet
     address=192.168.2.1/30 network=192.168.2.0 interface=gi2 actual-interface=gi2
 3 D address=69.165.165.24/32 network=206.248.155.132 interface=ISP actual-interface=ISP
The routes are all present and show as connected:
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADS  0.0.0.0/0                          206.248.155.132           1
 1 ADC  192.168.1.0/24     192.168.1.1     br-vlan10                 0
 2 ADC  192.168.2.0/30     192.168.2.1     gi2                       0
 3 ADC  192.171.61.116/30  192.171.61.117  br-vlan20                 0
 4 ADC  206.248.155.132/32 69.165.165.24   ISP                       0
The following hosts are alive, well and reachable from the router:
Router> ping count=3 192.168.1.3
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 192.168.1.3                                56  64 0ms
    1 192.168.1.3                                56  64 0ms
    2 192.168.1.3                                56  64 0ms
    sent=3 received=3 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
Router> ping count=3 192.168.2.2
    0 192.168.2.2                                56  64 0ms
    1 192.168.2.2                                56  64 0ms
    2 192.168.2.2                                56  64 0ms
Router> ping count=3 192.171.61.118
    0 192.171.61.118                             56  64 0ms
    1 192.171.61.118                             56  64 0ms
    2 192.171.61.118                             56  64 0ms
So lets just pick a few source addresses on the router and try to reach some of these hosts from different interfaces on the router:
Reachability using 192.168.1.1 as the source
Router> ping count=3 src-address=192.168.1.1 192.171.61.118
    0 192.171.61.118                                          timeout
    1 192.171.61.118                                          timeout
    2 192.171.61.118                                          timeout
    sent=3 received=0 packet-loss=100%
Router> ping count=3 src-address=192.168.1.1 192.168.2.2
Router> ping count=3 src-address=192.168.1.1 206.248.155.132
    0 206.248.155.132                            56  64 11ms
    1 206.248.155.132                            56  64 11ms
    2 206.248.155.132                            56  64 11ms
    sent=3 received=3 packet-loss=0% min-rtt=11ms avg-rtt=11ms max-rtt=11ms
Reachability using 192.168.2.1 as the source
Router> ping count=3 src-address=192.168.2.1 192.171.61.118
Router> ping count=3 src-address=192.168.2.1 192.168.1.1
    0 192.168.1.1                                56  64 0ms
    1 192.168.1.1                                56  64 0ms
    2 192.168.1.1                                56  64 0ms
Note: 206.248.155.132 is not expected to be reachable from 192.168.2.0/30
Reachability using 192.171.61.117 as the source
Router> ping count=3 src-address=192.171.61.117 192.168.1.3
    0 192.168.1.3                                             timeout
    1 192.168.1.3                                             timeout
    2 192.168.1.3                                             timeout
Router> ping count=3 src-address=192.171.61.117 192.168.2.2
    0 192.168.2.2                                             timeout
    1 192.168.2.2                                             timeout
    2 192.168.2.2                                             timeout
Router> ping count=3 src-address=192.171.61.117 206.248.155.132
    2 206.248.155.132                            56  64 10ms
    sent=3 received=3 packet-loss=0% min-rtt=10ms avg-rtt=10ms max-rtt=11ms
So the question then is why can’t hosts/interfaces on the directly connected subnet 192.168.2.0/30 and 192.168.1.0/24 reach hosts/interfaces on the directly connected subnet 192.171.61.116/30? This worked just fine before the upgrade, that is the only thing that has changed (and yes, if I revert to 6.32.2, it works again!)
Many thanks for any suggestions!
