I have just upgraded to 6.34rc45 on x86 and y could not connect to thedude server anymore. Error 10061 is shown.
Please generate supout file on this dude server and send it to support@mikrotik.com
sent,
I have the same issue. If i run /dude print (twice), dude server starts running for some time.
Same issue! error 10061.. i’ll send supout file…
Help a little trick:
[delix@Djankoy] > dude print
enabled: yes
data-directory: dude
status:
enabled: yes
status: applying settings: enabling: reading db object #168
enabled: yes
status: running
After print command dude starts working. Thinking to make script to use print every 10 sec =)))
when it gives error 10061 dude server is not working, data is not colected from devices.
error seems to be fixed in 6.35rc1
