Upgrades and DNS
My setup has a RB760iGS as the router, a RBcAPGi-5acD2nD, a RBcAPL-2nD and a RBmAPL-2nD, the 3x APs are all running as CAPs off the router, with the interfaces all configured for DHCP also from the router.
The RB760iGS and the RBcAPL-2nD both upgrade with no issues, from 7.21 to 7.22.1.
The other two APs RBcAPGi-5acD2nD and RBmAPL-2nD cannot resolve the DNS name for the upgrade packages.
Below are the DNS setting from each device, i am happy to provide further details…
RB760iGS - upgrade works
[admin@MikroTik] > /ip dns print
                      servers:
              dynamic-servers: 212.159.6.9
                               212.159.13.49
               use-doh-server:
              verify-doh-cert: no
   doh-max-server-connections: 5
   doh-max-concurrent-queries: 50
                  doh-timeout: 5s
        allow-remote-requests: yes
          max-udp-packet-size: 4096
         query-server-timeout: 2s
          query-total-timeout: 10s
       max-concurrent-queries: 100
  max-concurrent-tcp-sessions: 20
                   cache-size: 2048KiB
                cache-max-ttl: 1w
      address-list-extra-time: 0s
                          vrf: main
           mdns-repeat-ifaces:
                   cache-used: 258KiB
RBcAPL-2nD - upgrade works
[admin@MikroTik-cAP1] > /ip dns print
servers:
dynamic-servers: 192.168.3.254
212.159.6.9
212.159.13.49
use-doh-server:
verify-doh-cert: no
doh-timeout: 5s
allow-remote-requests: no
cache-size: 2048KiB
cache-max-ttl: 1w
vrf: main
mdns-repeat-ifaces:
cache-used: 36KiB
RBcAPGi-5acD2nD - upgrade fails
[admin@MikroTik-cAP-XL] > /ip dns print
                               212.159.13.49
                               212.159.6.9
                               212.159.13.49
               use-doh-server:
              verify-doh-cert: no
                  doh-timeout: 5s
                   cache-size: 2048KiB
                cache-max-ttl: 1w
                          vrf: main
           mdns-repeat-ifaces:
                   cache-used: 45KiB
RBmAPL-2nD - upgrade fails
[admin@MikroTik-mAP2] > /ip dns print
servers:
212.159.6.9
212.159.13.49
use-doh-server:
verify-doh-cert: no
doh-timeout: 5s
cache-size: 2048KiB
cache-max-ttl: 1w
vrf: main
mdns-repeat-ifaces:
cache-used: 36KiB
And what is the failure message?
Both failing APs have the same message…
[admin@MikroTik-cAP-XL] /system/package/update> check-for-updates
channel: stable
installed-version: 7.21
status: ERROR: could not resolve dns name (timeout)
