Hi, We have an RB1000 powerpc e500v2 1333MHz running ROS v.4.10. There is no queue involved.
Can I safely upgrade to V.5.26, and then to 6.42.2 without running into hardware/OS compatibility problem?
Thanks in advance..
Alex Duval
Thanks in advance..
Alex Duval
it will drop interfaces 99.9% ![]()
i mean after upgrade you will need to set them accordingly, vlans to ether x etc. this will happend, i dont recognize exactly after 5.26 i think to 6.x
I would export config, netinstall and then import config. You might need to tweek config before import due to version differences.
