Hi everyone,
Can someone advise me if I misconfigured something or if I am doing something wrong?
I am trying to upgrade the CAP ax. I have downloaded the the packages for it and placed them in files.
Added file path in CAPsMAN where packages are, does seem to do anything and when trying to click update button says it cannot find the files.
config:
# 2024-06-08 19:50:35 by RouterOS 7.15
# software id = 3ZSU-PBZW
# model = RB5009UPr+S+
# serial number = ********
add admin-mac=******** auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=Port1 name=Fiber_eth1
/interface vlan
add interface=Fiber_eth1 name=vlanfiber vlan-id=911
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec1
/interface wifi configuration
add country="United Kingdom" datapath.bridge=bridge disabled=no mode=ap name=\
2ghz security=sec1 ssid="Home - Wi-Fi"
add country="United Kingdom" datapath.bridge=bridge disabled=no name=5ghz \
add address-pool=default-dhcp interface=bridge lease-time=3d name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add comment=defconf interface=vlanfiber list=WAN
/interface wifi cap
set caps-man-addresses="" certificate=request discovery-interfaces=bridge \
enabled=yes
/interface wifi capsman
set ca-certificate=auto enabled=yes package-path=/packages/ \
require-peer-certificate=no upgrade-policy=suggest-same-version
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=2ghz \
supported-bands=2ghz-n,2ghz-g,2ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=5ghz \
supported-bands=5ghz-a,5ghz-n,5ghz-ac,5ghz-ax
192.168.88.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.253 client-id=********** mac-address=\
*********** server=defconf
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
