Hi, thanks for taking the time to read my post.
I have a couple basic questions on upgrading firmware that I am surprised to not see in the FAQ or Wiki, at least in the spots regarding upgrading or downgrading. I also searched Google a few times and have come up short.
Question #1: When upgrading firmware, should I upgrade the firmware on the CPEs or the APs first? If I upgrade the APs first, will the CPEs lose connection? I am at least one major revision and multiple minor revisions behind the newest firmware. What is the upgrade process for this? Upgrade the APs to a newer, but not the latest, firmware version, then do the same on the CPEs, then upgrade the APs to a newer one, and repeat the process on the CPEs until I am at the latest version?
For example: I have an AP and CPEs running v5.22. Do I need to press ‘Check for Updates’ on the AP first, upgrade to 5.26, then do the same thing for the CPEs? Then once the CPEs and APs are at 5.26, repeat this process until I am at v6.9?
i.e.,
AP: 5.22 > 5.26
CPE: 5.22 > 5.26
AP: 5.26 > 6.9
CPE: 5.26 > 6.9
Is this the correct process?
Question #2: When I press ‘Check for Updates’ under System > Packages, it says the latest package is 5.26. I am running 5.22. When I upgrade to 5.26, and then press ‘Check for Updates’ again, will it continually give me the newest package I can upgrade to until I reach 6.9?
All of my units are using firmware 5.22 or around there.
