Upgrading from 3.13 to 3.14 failure!!!!
I have upgraded my mikrotik router OS from 3.13 to 3.14 but the queues were working in 3.13 but now in the 3.14 are not working.
Can anybody helps me it is so urgent!!!
post your queues here. what exactly is not working with them?
their is something in tx and rx they are not counting
but ineed 3.14
if you are using an empty queue, make sure it’s type is “default” not “default-small”
I am sure it was default not default small
can it be something else?
post your queues please, I can’t tell the problem if I don’t know your config :slight_smile:
I solved my problem the type was default small
i put it default and the queues are working now
Thanks.
But i have another question:
what is the difference between default and default-ethernet?
Ethernet-default and Default are from the kind pcq so what is the difference???
and again sorry for being annoying!!! :smiley:
Default kind is not pcq.
These are default values nad there is no difference between default and ethernet-default.
0 name=“default” kind=pfifo pfifo-limit=50
1 name=“ethernet-default” kind=pfifo pfifo-limit=50
