I am not really sure what you are trying to do…
You say you ve upgraded to 6.45.6 …
So the question is, you want to downgrade to an earlier version or you want to upgrade to the latest vesrion ?
Yesterday I was able to upgrade the bios. The protected routerboot thread was a bit confusing so I’m writing what I did:
I ran latest stable netinstall of 6.45.6 (stable channel) under win 7 compatibility settings in windows 10 and checked the “apply default config” box
Now device is at 6.43.7. Then, I uploaded via the files menu the universal 6.43.7 bootloader file and ran again
/system routerboard upgrade /system reboot
now when i run
/system print
it shows
Current firmware 6.43.7
Now leds blink in a different way at boot and when going into netboot mode (need to press the reset button when router is booting up and leds need to blink for 10 seconds, then release the reset button)
