upgrading RB153
I have historical RB153 with ROS 2.9.38
can i upgrade it to 3.30 or 4.17? Is it problem or not?
I want to do it remotely via windox.
maslo
remotely is risk, but… :slight_smile:
what BIOS do you have?
latest is 2.18 http://www.routerboard.sk/files/firmware/rb153/adm5120-2.18.fwf
upload to files, then
/system routerboard print
and
/system routerboard upgrade
reboot
then upgrade ROS to version 3.30, then update licence key to new (/system licence - update licence key)
then upgrade to 4.17 a then to 5.9
disable or uninstall unused packages
enjoy :smiley:
routerboard: yes
model: “153”
serial-number: “13FE01D0D967”
current-firmware: “2.7”
upgrade-firmware: “2.6”
after upgrade:
routerboard: yes
model: “153”
current-firmware: “2.18”
upgrade-firmware: “2.18”
honzam,
thank you
RB153 is now successfully remotely upgraded without any problem.
DAKUJEM.
maslo
If I helped you, you can add me karma :slight_smile:
