Hi.
I tried to upgrade directly from 3,7 to 4,17 but no.
Do i have to upgrade to a version in between before going “all the way” to 4,17?
Lasse aka Norway.
Hi.
Lasse aka Norway.
upgrade to latest 3.x release that is 3.30 and then update license to new 8 symbol style. Afterwards you should be able to update to newer RouterOS versions.
also you can do this in one take, by using the netinstall tool
There is small problem. On download site is for PowerPc only Version 4.17.
3.30 you have only for mipsle.
Users must use an alternative link http://files.shelbybb.com/mikrotik/3.30/all_packages_ppc/
better use netinstall to reinstall router.
