I need to do in-place upgrade from 750GL to Hap AC2. If I export and import (both are on ROS 7.11.3) I run out of space on the new router, so I decided to set it up from 0.
I probably don’t see something obvious since client can’t access the local LAN, nor there is internet flowing. Client seems to connect, but can’t ping anything on the remote LAN (General Failure).
router:
# 2024-09-17 23:36:46 by RouterOS 7.11.3
# software id = 8LP6-A8W9
# model = RBD52G-5HacD2HnD
# serial number = xxxxxxxx
add admin-mac=74:4D:28:1E:A7:43 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=SET1 wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX distance=indoors frequency=auto installation=indoor \
mode=ap-bridge ssid=MikroTik-1EA748 wireless-protocol=802.11
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
dooba
/interface wireguard
add listen-port=13231 mtu=1420 name="WG VPN"
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk mode=dynamic-keys \
supplicant-identity=MikroTik
/ip hotspot profile
add name=default-dhcp ranges=10.10.0.200-10.10.0.240
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=wlan2
/interface detect-internet
set detect-interface-list=WAN
add comment=defconf interface=pppoe-out1 list=WAN
/interface wireguard peers
add allowed-address=10.10.5.2/32 interface="WG VPN" public-key=\
"vNMNJL0Kw691o8lOUN1a7bpUeVIWbBs2N5QVmc5QUzo="
add address=10.10.0.1/8 comment=defconf interface=bridge network=10.0.0.0
add address=10.10.5.1/24 interface="WG VPN" network=10.10.5.0
/ip dhcp-client
add address=10.0.0.0/8 comment=defconf dns-server=10.10.0.1 gateway=10.10.0.1 \
netmask=8
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=10.10.0.1 comment=defconf name=router.lan
established,related,untracked
add action=accept chain=input comment=WG dst-port=13231 protocol=udp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip service
set telnet disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Skopje
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
This is the client config:
[Interface]
PrivateKey = wKbcpQzvfbfB9XjgO9lpt6WzQ+H3tdx2dllb6ZeAvEc=
Address = 10.10.5.2/32
DNS = 8.8.8.8
[Peer]
PublicKey = GlSdxtCl0Cgf96KS3cFJ0Q1iXXSX1vi640ZiwVrD1F8=
AllowedIPs = 0.0.0.0/0
Endpoint = Public IP:13231
PersistentKeepalive = 10
